What is AWE-Q
Note
This document is currently under active development. Content may be updated, revised, or removed without notice.
This document describes how Audio Weaver has been integrated on the Qualcomm Snapdragon SOC using low-level APIs. It bypasses Audio Reach and provides significant performance improvements. This document should be used in conjunction with the generic description of the Audio Weaver architecture described in Audio-Weaver--Architecture. The overall design is flexible enough to handle all automotive use cases and configurations. You should be able to fully engineer your automotive audio system using Audio Weaver without having to write custom Hexagon code. (Unless, of course, you want to write your own custom modules that execute on the Hexagon).
The platform specific code needed to wrap Audio Weaver is referred to as the Board Support Package (BSP). We will use the term BSP throughout this document to describe this code. The BSP code is based on Qualcomm low-level AudioLite __ APIs. This is a low-level software layer which provides an RTOS, TDM port I/O, and basic system features.
The document covers integrations on the Gen4 SA8255 and the Gen5 SA8397 / SA8797 chipsets. The integrations are very similar and when they diverge, we will separately document each integration.
Watch the AWE-Q Demo Video:
Platform Features
  • Graphical development
  • Multicore support - distribute audio processing across all Hexagon DSPs and Arm cores.
  • Unified signal flow showing an overall view of all cores and threads
  • Integrated profiling. Per core, per thread, and per module.
  • Highly optimized Hexagon and Arm NEON code. Gen5 includes HVX support providing a significant performance uplift.
  • Access to IP
    • Over 500 Audio Weaver modules
    • Qualcomm voice IP
    • Custom module API
    • 3rd party ecosystem
  • Real-time audio features
    • TDM serial port configuration via Audio Weaver modules
    • Independent TDM ports automatically synchronize to within 1 sample
    • ALSA I/O configuration via Audio Weaver modules
    • Low latency - as low as 0.5 msec digital-in to digital-out using a 0.25 msec block size
    • Early audio within 1.5 seconds
    • Resynchronizes automatically after CPU overrun
  • Software integration
    • BSP configurable via a text initialization file
    • Run-time control via TinyMix APIs
    • Text based control API with integrated data type, range, and array bounds checking
    • awemgr_shell application for integration testing
    • Subsystem Restart (SSR) feature reboots DSPs and restarts the Audio Service if there is a critical run-time failure
    • Asynchronous event handling
    • Supports low power suspend and wake up
  • Full-featured Matlab API for scripting and regression testing
  • Supports all automotive use cases with concurrent operation
  • TFLM and ONNX support
  • Fully documented
  • Online training available
Advantages of Using Audio Weaver
  • Developed for high-performance automotive audio. Multiple concurrent use cases.
  • Constant / deterministic real-time load
  • Can load cores to 70%
  • Native low-latency support. End-to-end digital latency of 2 x block size. Block sizes as small as 12 samples at 48 kHz support for an end-to-end digital latency of 0.5 msec.
  • TDM ports aligned within 1 sample
  • Easy to understand profiling. Per module, per thread, and per core. Show average and peak CPU load.
  • Supports all cores including Arm cores.
  • Includes integrated visual debugging tools and legacy QXDM.
  • Architecture is fully documented and information is publicly available.
