Designer Release Notes
8.2026.1 (8.D.4.2)
2026-Jun-29
NEW FEATURES
  • Updated Designer licensing to new QLM key based authentication
  • Made changes to support MATLAB r2025a and later, including updates to all matlab based GUIs to use App Designer instead of GUIDE
  • Designer now supports rendering non-Latin canvas and annotation text on Asian-locale PCs
  • Converted all Designer and Module documentation to markdown formatting
  • Added a Filter Noise Floor Analyzer tool in Designer. This calculates noise floors for biquad modules in a layout and compares to other biquad types
  • The Native target now supports AWE Core log and event messages using callbacks into files
  • Added a new 'Logging Options' designer menu under the Tools tab to control the log level and log type
  • Including a VectorLib_Public.h file in Designer installers so module writers can use common, portable, and optimized DSPC VectorLib functions
ENHANCEMENTS
  • Updated CRUS generation to allow more efficient processing and memory use
  • Improved positioning of matlab based menu GUIs, including for vertical monitors
  • Module help docs will now launch in a focused browser
  • Updated Wire Buffer Pools (beta feature) to improve efficiency and to allow multiple Buffer Pools to be used across heaps
  • Added ability to use MIT Licensing in custom module generated C code
  • Designer title bar now shows whether the input audio is from a File or Line Input for the Native target
BUG FIXES
  • Improved Designer startup behavior and robustness in both Pro and Standard
  • Removed matlab errors about progress bar on Designer launch on some systems
  • Fixed propagate changes button so it now will show updated module statuses on the canvas when clicked during runtime
  • Updated saving .awj's in Pro edition to avoid small differences with file saved from Standard
  • Added support in Peak Profiling for more than 14 threads
  • Removed tab chars from profiling results, and suppressed opening of all instance .csv's in multi-instance profiling
  • Fixed several issue with file search path, including one that required restarting AWE_Server for changes to take effect
  • Changed default setting for Enable Bundled Packets to off in Generate Target Files menu
  • Fixed issue where destroying a layout while tunnelled would continue to display a CPU load on Native target
  • Updated subcanvas tunneling to display a warning message when it fails. Previously it would fail silently
  • Fixed several typos in AWE Server Preferences dialog
  • Disabled changing target system types in Layout Properties menu
  • Fixed linker warning in generated custom module Visual Studio files
  • Fixed Process File tool hanging indefinitely for specific layouts and audio files
  • Fixed several fract32 modules that were interpreting fract32 variables as nan's
  • Fixed MixerV3 inspector so it now consistently shows all output channel names
  • FifoIn/OutV3 is not longer being left out of ModuleList.h in multi-instance systems
  • Prevented assignment of custom objectIds to matlab subsystem modules
  • Improved Preset robustness by only copying if className is the same
  • Improved robustness of renaming, deleting, undoing, etc. of Subsystem pins
  • Improved speed of Redraw time in Designer
  • Improved robustness of feedback wire handling in cases where feedback wire is not required
  • Fixed issue where Subcanvas worker threads weren't always honored on single instance targets
  • Prevented failed rename of interpreted modules from .mtemp to .m
  • Fixed various places where a failure during propagation or build would not pan to the offending module
  • Improved handling of errors thrown by default prebuild and postbuild matlab functions
  • Improved error messaging for matlab transmit errors
  • Fixed problem with CRUS generation for complex modules with assigned objectIDs
  • Removed warnings caused by using backslash in inspector controls
  • Improved error message when pin destination connection does not exist
  • Now correctly flagging build error when using block size > max allowable
  • Fixed potential issue where matlab warnings could be shown as unrelated error
  • Modules that were converted to interpreted could fail to load from .awj
  • Fixed some unnecessary warnings about datatype mismatches for sample rates
  • Fixed bug where failing postbuild function caused the system to stay marked as live
  • Long AWD or module names in dialog boxes are no longer cutoff
8.2025.3 (8.D.4.1)
2025-Dec-31
New Features
  • Added Subcanvas module feature, which enables the encapsulation of .awb's inside a module. See Designer documentation for more details
  • Created preset groups and preset fields for all module variables. Added a Preset Editor tool in Designer to create, apply, and save presets
  • Introduced System Clock Source section in Layout Properties menu to show the current systems I/O properties
Enhancements
  • Updated Generate Target Files menu to include AWC file generation
  • Increased the amount of logging printed in the Messages tab of AWE_Server
  • Updated profiling to display per thread CPU load when core affinity is set on the target
  • Created the ability to access matlab module arguments with M.argument. syntax. The original syntax using M.constructorArgs{i} is still supported
  • Added a field in AWE_Server Preferences menu to change the Native target's fundamental block size
  • Made alignment of arguments and arrays more consistent in the Module Properties view
  • Improved error and warning messages in matlab
Bug Fixes
  • Fixed some incorrect memory profiling issues, especially in multi-instance systems
  • Fixed an issue in peak profiling when number of layouts exceeded the number of samples being collected, or if profiling non-contiguous instances
  • Fixed an issue where an error occurring during a postbuild call could cause it to be skipped in subsequent builds
  • Removed call to postbuild from Attach to Running Target for classic builds. It could result in overwriting values on the target
  • Fixed issue where Attach to Running Target could show stale target information in profiling results
  • Fixed a problem with Navigate Up not always going to the direct parent subsystem
  • Updated Designer to ignore clock dividers on virtual modules to avoid erroneous 'too many threads' build errors
  • Fixed an issue with feedback wires when used in an matlab subsystem module and hierarchical builds
  • Fixed some issues with feedback wires not inheriting data type and clock divider properly for Hierarchical builds
  • Corrected the behavior of copy paste of feedback wire properties so connections point to valid modules
  • Improved robustness of loading a layout with a missing module. It could lead to the layout being uneditable
  • Fixed Revert to Subsystem action on RUS so that wires do not disappear
  • Fixed ability to open an AWD containing a RUS when that RUS has changed its I/O pin count
  • Destroy after Attach to Running Target no longer freezes the canvas when a subsystem output is directly connected to HW output pin
  • Fixed a number of corner cases when using objectAlias names that could lead to name conflicts or stale names
  • Fixed an issue with Native target where latency across multiple threads may not be consistent
  • Now allowing range information for module variables to be updated during load time
  • Improved the compatibility of matlab modules by allowing reordering of the module arguments
  • Corrected evaluation of a comma separated list of arguments when some of the arguments are layout variables
  • Propagate changes now updates layout variables if the hw input pin properties have changed
  • Allocation priority is now being persisted for CRUS modules
  • Added ChangeThreadV2 to the CRUS exclusion list
  • Fixed an issue with generating CRUS that have no input pin
  • Fixed an issue while creating a CRUS with a user inspector control that points to a Debug module. This control is now automatically removed during CRUS generation
  • Corrected the behavior of copy/cut pasting a module that was being controlled by a StatuSet type of module. It was previously causing an error
  • Changed the default behavior of 'isRangeEditable' for module variables and arrays to true. This will take effect after modules are regenerated
  • Added a matlab process function to the scaler_module_interpreted example module
  • Updated the FrameDll.lib used by custom module packs in installed editions to be up to date
  • Aligned AWJ saving from Designer and matlab scripts so that output AWJs will be identical
  • Fixed warning message thrown when a module pack's classid.csv is missing
  • Removed duplicate find_module matlab function and replaced all usage with equivalent get_module
  • Cleaned up usage and behavior of classid_lookup changed create_module_by_id function to create_module_by_mfile_name
  • Added support for 'uint' data types in generate_mfile.m script
  • Fixed a bug with resaving existing Inspector Groups after moving their positions
  • Updated search path in matlab framework to look in matlab path last instead of first
  • Made sure that AudioWeaver/matlab path is included in search path when using Custom Module Wizard
  • Added a error message if trying to open Global Preferences if AWE_Server is not running
  • Added a progress bar to AWD saving when the AWD version is being updated
  • Fixed fract32 filter checkbox in the module palette. It was not filtering fract32 modules correctly
  • Fixed issue where hierarchical builds could share the input wire buffer potentially causing wire memory corruption
AWE Designer 8.2025.2.A
2025-Aug
Bug Fixes
  • Fixed an issue with TypeConversion modules, where if they changed to/from different bit width sample types, the wire could be erroneously shared
2025-Jun
New Features
  • Designer Installers now include the BuildFlash executable, which can be used to generate .bins to store files in flash memory
  • Added new hotkeys for profiling in Designer, and improved documentation of existing hotkeys
  • Added support for fract16 wires and module variables
Enhancements
  • Reduced the time it takes to delete, cut, or rename modules in large systems
  • Added support for matlab subsystem modules to be interpreted
  • Made matlab startup code more robust, including no longer failing if TaskList is not available on the system
  • Added more logging and error checking in AWE_Server and Designer launching code
  • Improved consistency of display of floating point values in module properties, and no longer truncate array values will loading/storing from .csv
  • DateTime module now shows date and time in hexadecimal
  • Commas are now supported in module arguments
Bug Fixes
  • Fixed an issue with profiling being incorrect on multi-instance targets when tuning master instance is > 0
  • Added support for correctly profiling memory usage for modules that allocate memory in Set functions
  • Fixed error when doing manual profiling of a layout that contains an empty subsystem
  • Fixed a failure with freshly loaded layouts and Attach to Running target
  • Generating target files will now only delete the files exactly matching the names of the newly generated files
  • Hierarchical builds now generate custom objectID set commands in target files
  • Adding a new HW pin will now mark the system as modified
  • Fixed an issue in the search bar where certain search strings were causing the results to be incorrectly indexed
  • Cleaned up the formatting of certain warnings and errors for better readability
  • MHz column in profiling results no longer shows results in scientific notation
  • Fixed an issue with renaming subsystems if a similarly named subsystem is already opened
  • Improved error message for a missing layout variable to include the module using it
  • No longer redrawing the canvas between design and run mode
  • Corrected the CPU load calculation in AWE_Server by applying clockDivider factor
  • Removed opening of About dialog when Standard Designer is first launched
  • Removed the 'x' box on the progress bar while building a layout. This action cannot be canceled
  • Generating ModuleList.h for multi-instance targets will now only create .h file for instances that are used in the layout
  • No longer showing the assign objectID right-click option for virtual modules
  • Fixed saving array values to .csv for complex numbers
  • Fixed an issue with reverting a RUS to subsystem when the RUS was created with an old Designer version
  • Error is now properly generated if creating a RUS from a subsystem that already contains a RUS
  • Fixed issues with FeedbackSettings module that were causing spurious build errors
  • Usage of StatusSetV2 will now always correctly set the 'controlled by' field for target modules
  • Fixed issue with converting a subsystem with controlling modules (e.g. StatusSetV2) in the subsystem
  • Improved installers by allowing them to be run twice without corrupting DLL registration scripts
  • Updated AWJ JSON schema 3.3 for missing entries and inconsistent data types
Misc
  • Removed PyAweCore from Designer installers. To get access to this package, contact DSPC support
AWE Designer 8.2025.1
2025-MARCH
New Features
  • New Hierarchical build engine can lead to faster build times and more control over layout
  • Improved functionality of Designer search bar, and added support for keywords. See Designer documentation for more details
  • Added 'Go To' module option in right click menu for controlling modules (ParamSet, etc.) and the modules they are controlling
  • Added 'Copy Name' right click menu option for copying module names
Enhancements
  • Right-click menu will now have a submenu for opening each inspector panel in a subsystem if there are more than one
  • Improved a variety of inspector display issues
  • Added support for unicode text in annotations
  • Improved handling and searching of audio input files in Layout Properties
  • Sped up load/save time for AWJ by ignoring obsolete connection array
Bug Fixes
  • Fixed issue where layouts with missing CRUSs were failing to load
  • Fixed and added clarity to error message when creating a CRUS with inspectors that targeted matlab subsystem modules
  • Corrected the heap size reported for CRUSs in profiling results
  • Fixed bug where CRUS with more output pins than inputs would incorrectly share output wires
  • CRUS inspector panels now copy all control settings (colors, fonts, etc.) from original subsystem
  • Fixed potential crash issue in AWE_Server Native target when profiling was disabled
  • Fixed issues with handling binary port packages in AWE_Server for multi-instance Native target
  • Fixed drawing of CPU threads in AWE_Server to use the full width of the window
  • Improved robustness of Convert to Subsystem tool to prevent Designer freezing
  • Now only send a Set command for module vars of type 'parameter' when opening module inspector
  • Fixed problem with setting module parameters from the module properties tab during runtime when minimize target read/write option is set to true
  • Fixed issue with right-click Help option for interpreted modules in module browser
  • Checking for missing modules in subsystems is now done on the correct instance
  • Resolved a routing error that was incorrectly reusing wires for unterminated and terminated module output pins
  • Fixed loading layout by dragging and dropping from a folder when the layout name contains special characters
  • Removed checking for valid ranges on subsystem input pins, which was causing issues in corrupted layouts
  • Fixed some issues with preserving channel names when converting to subsystem or deleting/undoing
  • Fixed issues with loading and saving module states in AWJs
  • Fixed issue with loading and saving module const variables in AWJs
  • Preventing corruption of annotations in AWJs, and also more robustly loading AWJ if there is corruption
  • Doing a Save As on an AWJ file will now default to AWJ save file type
  • Fixed layout loading progress bar to say 'AWJ' when loading an AWJ
  • Canvas size is now persisted when it is changed due to copying
  • Added calls to the matlab module PrepareToSave function when saving layout
  • Fixed issue when modules in layout are not found on the system not fully deleting them from the layout
  • Fixed issue with loading layouts that had an empty inspector panel
  • Fixed hierarchical build using inspectors with non-zero instanceId
  • AWDs marked in windows as read-only files will now not be savable in Designer
  • Fixed issue with using layout variables in ChangeThread module
  • Scaler inspector will now properly show dB or linear based on module settings
  • Fixed error message for pins being on different threads to show entire message
  • Fixed Sink inspectors so scalar values are not truncated
  • Improved message for insufficient threads error to state which instance the problem is on
  • Improved error message for feedback wires that transcend instanceId
  • Fixed some comments in generated _ControlInterface.h files
  • Fixed help text for awe_version matlab function
AWE Designer 8.D.2.7
2024-DECEMBER
New Features
  • Added option in Generate Target Files to split multi-instance layouts into multiple AWBs to support Progressive Loading
  • Added support for 2M, 3M, and 6M baud rates for RS232 targets in AWE_Server
  • Added ability to copy/paste wire information like names and delays between wires in Designer
Enhancements
  • Increased the maximum binary message length from 1024 to 4096 to support larger tuning messages
  • Missing modules in subsystem modules are now checked at the beginning of builds
  • Improved application of layout variables at build time to avoid unnecessary updates for unchanged variables
  • Version overwrite save warning dialog now only pops up first time saving layout with new version
  • Improved handling of copying modules with objectIds defined
Bug Fixes
  • Updated uninstallers to no longer deregister AWETalkToGUI COM Server, and improved error messaging for this issue
  • Fixed Pro Designer launching with MATLAB 2024a and later
  • Fixed compatibility issue with loading complex numbers in AWDs
  • Fixed potential subsystem pin corruption in AWJ's when changing input pin data type
  • Corrected saving and loading of channel delays in AWJ
  • Fixed saving and loading measurements in AWJ files
  • Improved saved information in AWJs to better support range definitions
  • Corrected error message when opening a corrupted AWJ file
  • Fixed issue with AWJ files containing empty subsystems
  • Fixed problem creating CRUS from subsystems containing multiple inspector panels
  • Fixed loading layouts containing a RUS or CRUS that is not found on the module path
  • Fixed loading layouts containing non-English characters
  • Fixed issue with feedback wires being set on subsystem output pins
  • Fixed issue with intermediate files not being deleted when interpreted module execution fails
  • Fixed issue in error dialog where block size range was printing junk characters
  • Corrected heap allocation failure error message
  • Fixed issue with channel name propagation into Router inspectors
  • Custom channel names are now retained when changing number of input pins on downstream module
  • Fixed some alignment issues in module inspectors, and added labels for event button inspectors
  • Fixed crash issue when executing an AWS from AWE_Server while an inspector is open in Designer
  • Fixed potential CPU % load difference between Server and Designer profiling for some multi-instance layouts
  • Fixed wire memory profiling when using Bind First build option
  • Fixed potential hang in Tuning Interface test with slow connections
  • Clarified that biquads used in Tuning Interface test tool are stereo
  • Fixed dialog cutoff issue in About dialog in Designer
  • Updated ASIO device menu button to say 'Close' instead of 'Cancel'
  • Made it clear in AWE_Server preferences that heap sizes are defined per instance for native target
  • Fixed issue with .tsf file ignoring the override InstanceId field in Generate Target Files
  • Fixed rounding issue in displaying integer values in module documentation
  • Fixed Fader example module tests so they pass
AWE Designer 8.D.2.6
2024-AUGUST-15
New Features
  • Designer will now show error messages for invalid layouts when pressing Propagate Changes
Enhancements
  • Improved license authentication robustness for users who cannot access DSPC web license server
  • Updated AWD/AWJ formats to no longer require prebuilding layouts while loading
  • Made various internal improvements to improve layout build and load times
  • Updated JSON engine used internally for processing .json data for speed improvement
  • Added a warning for users when saving layout with newer AWD/AWJ version
  • Improved error reporting when attempting to generate a ModuleList.h file with an invalid layout name
  • Improved module I/O information included in profiling data
Bug Fixes
  • StatusSet execution order now behaves correctly for subsystem target module
  • Now preventing excessive get_module_state messages when using subsystem inspectors
  • No longer listing duplicate module classes in the missing module list dialog
  • Updated CRUS generation to throw error if using a ChangeThread module
  • Fixing build of some layouts using feedback wires across multiple subsystems
  • Deleting a module will no longer throw cryptic error messages if unrelated modules are not configured correctly
  • Corrected issue with stale clockDividers in Source modules when switching between single and multi-instance targets
  • Fixed issue in Native target where sample rate info from audio device was not being propagated to layouts
  • Improved robustness of renaming user inspector panels
  • Corrected handling of empty schema versions in CRUSs, and excluded pointer variable types from CRUS manifests
  • Fixed deleting CRUS/RUS from the module browser in the Standard edition
AWE Designer 8.D.2.5
2024-JUNE-29
New Features
  • Reduced load and save times for AWJ files, and updated AWJ version to 3.0
  • Added option in Layout Properties menu to force bind_wire commands to happen before other wire allocations
  • Added options in Generate Target Files menu to select target instanceID and to include a Lookup Table in the generated .awb/.aws
  • Added support for Multi-Instance in Module Tests tool
  • Added support for Multi-Instance and Multi-Canvas in the Tuning Interface Test tool
  • The minimum MATLAB version required for using Pro editions of Designer has been updated from R2017b to R2021b
  • Designer is no longer tested with MATLAB R2017b, so using this version may result in inconsistent or faulty behavior
Enhancements
  • Improved the validation of AWJ files against a custom JSON schemas
  • BuildFlash.exe tool now warns user when filenames are truncated due to length limitations
Bug Fixes
  • Fixed issue with building Multi-Canvas layouts when different instances have different block sizes
  • Improved error detection and message clarity for invalid subsystems with only a virtual module between input and output
  • Ensuring that correct target information is available in profiling after doing attach to running target
  • Fixed issue that was preventing layouts saved with invalid paths in ParamSet module from being loaded
  • Execution order for Param Set and Status Set style modules can now target modules in subsystems
  • Fixed issue where the 'controlled by' field for modules on the canvas was not always being updated
  • Removed support in Designer for module argument inputs beginning with '0b'
  • Fixed issue where module argument strings starting with '0x' were being improperly converted to decimal values
  • Fixed issue in Designer when running on Multi-Instance target with more than 16 instances
  • Updated AWE Server Flash Manager to be able to access different Flash File Systems on Multi-Instance or Multi-Canvas target
  • Loading and saving module arrays from file now maintains full precision
  • Fixing corruption in layout file after running process files
  • Fixing user inspector operability after running manual profiling
  • Fixed a number of issues that could cause Tuning Interface Test to hang, and improved flexibility of modules required to run the test
  • Fixed issue where copying an invalid subsystem to a new layout could corrupt the layout
  • Convert to Subsystem will now retain custom objectIDs for modules
  • Failed attempts of Convert to Subsystem now correctly restores original subsystem
  • Designer now throws a warning if the output HW pin is not fract32
  • Restored the right click Help option for RUS/CRUS on the canvas
  • Improved robustness of test_start_audio MATLAB function in the case of Multi-Instance targets
  • Fixed issue when loading layouts with out-of-sync module control information
